2550 GTS
2550 GTS
CLIMB ABOARD AND EXPERIENCE THE BLAZER BAY DIFFERENCE!
Introducing the latest from our NEW bay boats -the Blazer 2550 GTS. Featuring a padded hull with amazing performance, tournament ready and seating for the whole family.
25 Feet 5 Inches
33 Feet 6 Inches
8 Feet 6 Inches
13 Inches
Recommended HP
400
78 Gallons
Deadrise At Transom
15 Degrees
10 Inch Manual Shoemaster Jackplate
10 Micron Water Seperator
100% Composite Construction
2 – 1600 GPH Automatic Bilge Pump
2 – Aft Tournament Class Livewells Port & Starboard
3 – 1250 GPH Livewell Pump
6 Gauge T/M System
6 Stainless Steel Pull Up Cleats
Aluminum Console Grab Rail
Anchor Locker
Battery Cut Off Switch
Bow Mount Trolling Motor Plug
Built in Fish/Cooler Box / Floor Storage
Console Courtesy Lights
Deluxe Fold-Down Rear Seat w/Bilge Access
Deluxe SS Steering Wheel w/Knob
Electrical Breaker System Aft Control Panel
Glove Box & Misc. Item Bin
Heavy Duty Rubrail w/ SS Insert
High Density Foam Transom
Horn w/SS Cover
Huge Storage Compartments
Hydraulic Steering
Insulated bow step cooler box
LLeBroc Double Bolster Flip Down Seating w/ Flip Down Arms
Marine Grade Wires / Connections
New Forward Opening Console w/Large Access & 5 Battery Storage
New Port and Starboard Rod Lockers
Raw Water Washdown w/ Spray Heads
Stainless Steel Cup Holders
Stainless Steel Latches
Stainless Steel Locks
Stainless Steel Toggle Switch Panel
Storage Box in Floor For Net Storage
Under Gunnel Rod Storage
Under Seat Rear Bilge Access
